rassel_rabbi
Nov 04, 2025Follower
Inquiry: 24×1 Gbps Copper + 2x10G Copper & 4×10 G SFP+ Uplink - Layer‑3 Switch (non‑PoE)
Hello, I am looking for a Layer‑3 switch from NETGEAR with the following specifications: 24 ports of 1 Gbps copper RJ‑45 (non‑PoE) 2 ports of 10 Gbps copper & 4 ports of 10 Gbps SFP+ uplinks F...
schumaku
Nov 07, 2025Guru - Experienced User
Could Netgear confirm the GSM4328S is not EoL and continues to be available?
Full Layer‑3 routing features (static routing, inter‑VLAN routing, etc.)
On a side note, this list does not reflect the effective GSM4328S specs. It has only four (4) 10 Gb capable ports, two 10 Gbps copper for RJ45, and two 10 Gbps SFP+ ports; these ports usage is not limited to uplink only.
