rbizzell40
Dec 06, 2016Follower
Inter-vlan routing
My existing network is all on the native vlan of 1 not segmented at all. I have a new netgear 10G XS708T that I want to connect to network but create vlans for virtual machine traffic. This will be a...
Carl_z
Dec 06, 2016NETGEAR Expert
Hi rbizzell40,
Welcome to Netgear Community!
You can refer to this,may be it is helpful .
Beside this, I think you also need to add some static route. You can take a routing vlan as a L3 physical interface,and routing between vlan just work as L3 ip interface.
Regards
Carl
Netgear Employee
