tgrover
Jan 26, 2022Follower
Internet Connection Issues ProSafe GS728TP
I have some users that are experieincing problem connecting to the Internet. Sometimes they can, sometimes they can't and it is really sporadic. They are connected to a ProSafe GS728TP switch. I was ...
JeraldM
Jan 27, 2022NETGEAR Employee Retired
Welcome to the community!
One thing that you can check first is the connection of the computers to the switch, that being said, try using a laptop and an extra Ethernet cable which you'll use to see if you have Internet access on the switch ports.
If all ports seem to show that they have Internet on your laptop, then most likely the problem is with the cabling itself.
JeraldM
NETGEAR Community Team
