ClemensD
Mar 29, 2018Tutor
IP Address Conflict between Routing Interface and Interface vlan
Hello, we are using a management vlan for our switch einvironment. Therefore we configure the specified vlan interface with the appropriate ip address. Furthermore we set the management vlan inte...
- Jun 12, 2018
Hello,
the final update, i guess.
after some time of researching Netgear has been solved my issue with firmware 12.0.4.10.
It will we available for download soon.
Best,
Clemens
ClemensD
May 29, 2018Tutor
Hello,
for further analysis my case was redirected to the Netgear Engineering Team.
Best,
Clemens
DaneA
Jun 04, 2018NETGEAR Employee Retired
Hi ClemensD,
Thanks for the update. I also inquired about the update of your ongoing support ticket with NETGEAR Support and found out that the engineering team is working on a code that might fix the problem.
Feel free to post here any update about your support ticket with NETGEAR Support.
DaneA
NETGEAR Community Team
- ClemensDJun 12, 2018Tutor
Hello,
Best,
Clemens
