sstephens's avatar
Jan 30, 2018
IP Redirected to another IP
Hello,
I have a NetGear M4300-28G and I am trying to direct traffic from one IP to another. I need traffic on vlan 10 that asks for an ip of 10.10.100.30 to be redirected to 192.168.2.7 and traffic on vlan 1 that asks for 192.168.2.85 to be redirected to 192.168.2.9. We are changing some things on the network and would like to keep the gateways the same on all the clients. 10.10.100.30 is the IP for vlan 10 and 192.168.2.85 is the IP for vlan 1. I was hoping someone would have a suggestion, I have looked through the CLI manual and done some searching and have not found anything yet. If more information, a network diagram, or the switch's running config would help just let me know.
Thank you in advanced to anyone who helps
  • I have been looking into this further and beleive I may be able to do this with NAT. I couldnt find anything in the CLI manual about it so the switch may not have the ability to do it. I will keep digging, any assistance is appriciated.
    • LaurentMa's avatar
      LaurentMa
      NETGEAR Expert
      Hi sstephens, thank you for your message. No NAT actually on L2/L3/L4 Managed Switches, but Advanced ACLs (IP) will do it nicely. You just need to bind your ACLs to your respective VLANs and redirect any source IP traffic to any destination other IP, you can specify which kind of traffic, too. If routing is needed, then Policy-Based Routing (PBR) will use ACLs to modify IP routes. NETGEAR M4300 switches are very capable, please let us know if you need more information. The Community will help you.
      You will find the CLI manual and Web interface user manual in M4300 support pages. Commands are presented one by one. But best for your questions would be the Software Administration Manual which delivers practical examples (both using CLI and Web GUI). I would advise you consult the chapter 11 for ACLs (there is redirect ACL example page 204). If PBR is needed, you should consult the chapter 8 starting page 145. Let us know how it goes!
ProSupport for Business
