Drekko
Aug 19, 2017Aspirant
JGS516PE can this switch test bandwidth?
Hi
I have this switch and I am making my own Cat6 cables and terminating them etc
I have a cable tester but its a cheap one that does not show me what max bandwifth the cable can transfer
Is there a way the switch can tell me this info?
1 Reply
- HopchenProdigy
Hi,
No, the switch can't tell you that. Also, this is a gigabit switch so no matter how good your cables are, the speed of any device connected to the switch will never exceed 1Gbit/s. Cat 6 cables are usually made to carry 10Gbit/s traffic, but again you switch can't exceed 1Gbit/s on its ports and thus it is likely that the switch will be the bottleneck, not your cables.
