boxcee
Jan 22, 2025Aspirant
JGS516PE: How to assign VLAN to LAG?
How can I set a VLAN ID for the LAG on the JGS516PE? I don't find such a configuration screen. See my configuration so far.
boxcee
Jan 23, 2025Aspirant
Thank you for your reply.
I can see the link you posted relates to using a management VLAN. Does this mean it applies to LAGs as well?
schumaku
Jan 23, 2025Guru - Experienced User
For the management VLAN, LAG or single link doesn't make a difference.
For other ports (links), you can of course operate (one) untagged network, or as many tagged VLANs as you want to deploy.
