Cabinhaven
Apr 22, 2018Aspirant
JGS524PE - ProSafe Plus Utility , The switch and manager IP address are not in the same subnet.
Hi all, I have a JGS524PE ProSafe Switch running Firmware version 2.0.1.26 that have not been updated in a very long time. I wanted to update to the latest version firmware for this switch. ...
- Apr 26, 2018
Of course you cant reach it - the first is the switch default IP address, the second is the IP address of your WIndows system. As these are not in the same subnet, the 192.168.0.239/24 can't be reached. temporarily change the LAN IP address of your Windows system to some address in the 192.168.0.0/24 (255.255.255.0) network, like 192.168.0.123. Now you will be able to reach the switch.
Cabinhaven
Thanks, That does allow the ProSafe Utility to operate again. But it has the following effects:
1. My Laptop will now only operate on WIFI while the IP is set to match the ProSafe Utility 192.168.0.239.
2. when I tried to apply the new firmware 2.01.40 I get the following error:
schumaku
Apr 23, 2018Guru - Experienced User
Cabinhaven wrote:Thanks, That does allow the ProSafe Utility to operate again. But it has the following effects:
Yes, of course - the workaround was supplied to regain management control of your switch. Either to set an IP address matching your network, or ensure it's in DHCP mode so it will pick up a valid network config from your DHCP server (typically on the router). Then you cna revert the config change on your WIndows system again.
- CabinhavenApr 23, 2018Aspirant
Thank you for confirming the IP change is a workaround to regain control of the switch and that the IP change needs to be reverted. With the overall goal of upgrading the firmware on my switch I can now access the switch and the maintenance menu.
Although when I select the maintenance menu, then firmware upgrade, browse to the locally downloaded bin file to use and press "apply" I get this series of screens and unfortunately this error. (TFTP Timeout). See attached screenshots.
Would you or someone else be able to help me address this error in hopes that I can get the latest firmware to apply to the switch? Thanks for your time and help.
- schumakuApr 23, 2018Guru - Experienced User
Was not able to see the screenshot before, as all embedded images are under mandatory moderation why ever, so was not able to reply to your second question.
This looks like the switch does try to talk to the Windows 10 system where the utility is running, attempting to establish a tftp session to a tftp server run as part of the utility. If operating 3rd party firewall (or similar/related Internet security garbage [sorry]) - disable it. Running the utility as administrator might help, too.
I am running "Windows Defender". I will attempt to disable it and rerun the utility.
