Cabinhaven
Apr 22, 2018Aspirant
JGS524PE - ProSafe Plus Utility , The switch and manager IP address are not in the same subnet.
Hi all, I have a JGS524PE ProSafe Switch running Firmware version 2.0.1.26 that have not been updated in a very long time. I wanted to update to the latest version firmware for this switch. ...
- Apr 26, 2018
Of course you cant reach it - the first is the switch default IP address, the second is the IP address of your WIndows system. As these are not in the same subnet, the 192.168.0.239/24 can't be reached. temporarily change the LAN IP address of your Windows system to some address in the 192.168.0.0/24 (255.255.255.0) network, like 192.168.0.123. Now you will be able to reach the switch.
schumaku
Apr 24, 2018Guru - Experienced User
In private network mode, run the app as administrator (locate abdrichtxlick on the .exe) the ownership alone is not sufficient.
Cabinhaven
Apr 25, 2018Aspirant
Hello,
I am not familiar with how to do this step you suggested: (locate abdrichtxlick on the .exe)
What I did do is make sure both my wired network and active wifi network were both set to private. Change the PC IP address to 192.168.0.29 to match the Prosafe Utility.
Via File Explorer went to the ProSafe Utility EXE, right clicked on it and slected "run as admin". Sorry to say at the end I still got the TFTP Timeout. Can you help me with the (locate abdrichtxlick on the .exe) step you provide? I am unclear how to do this step.
Thanks for your patience. (note also reconfirmed I don't have any 3rd party virus protection running.
- schumakuApr 26, 2018Guru - Experienced User
Hm, some scratch text submitted by error, sorry.
Try to locate the ProSAFE Plus Utility.exe, located for example in C:\Program Files (x86)\NETGEAR\ProSAFE Plus Utility\ - right click, compatibility, tick Run as Administrator, and apply.
- CabinhavenApr 26, 2018Aspirant
Thanks,
Just for a recap, I went to Netgear.com and downloaded the ProSafe Utility that it said was most current for my JGS524PE switch. The EXE is date 8/6/2010. I have been able to right click on that EXE and run it in "Run as Administrator" but I get the same TFTP Timeout.
I then decided to remove the ProSafe Utility and Download the Utility and apply it again and I got this error WinPcap error message during the install. I am hoping this is my primary issue and if we can solve for this it may begin working? I do recall getting this when I initially downloaded the utility as well.
Might this be of any help?
Just to recap: My active wired and wireless networks are set to Private, No 3rd Party Virus protection is loaded on the PC, I have run the Utility from Files Explorer as "Run as Adminstrator".
Thanks again
Hi, I wanted to let you know that I was able to delete Win PCAP from my system and allow the Prosafe Utility Apply again and it did so without error this time. Sorry to say I still get the TFTP Timeout when it a run as admistrator.
I have even tried to apply the firmware with my router unplugged so I am off the internet but the results there were also TFTP timeout.
Any last thoughts? Thanks
- XavierLLApr 26, 2018NETGEAR Employee Retired
Hi ,
As you are already running the version 2.0.1.26 I would recommend to try to access to the switch using a web browser and try to upgrade the firmware from there. And later on try to use again the ProSAFE Plus Utility.
Please let us know if that works!
Xavier Lleixa
NETGEAR CBU PLM
Thanks,
What address do I use to get to the switch? Below is what ProSafe Plus shows?
If I currently use 192.168.0.239 or 192.168.1.40 I get the error that the site can't be reached. See print screens.
thanks
To all those who helped this novice, Thank You.
I finally gained access to the Web UI with all your help and once connected to the Switch the firmware upgrade went fast and flawless. I will document this for myself so I can do it in the the future if the ProSafe Utility is not an option.
Thanks very much!
