Gample_YT
Nov 27, 2024Follower
JGS524PE problem with reset and connect
Hi, I have a problem with the aforementioned NETGEAR JGS524PE switch. When I connect the power, it starts up, but all the LEDs light up and stay on, even though they should turn off shortly after sta...
schumaku
Nov 27, 2024Guru - Experienced User
Reads to me like a hardware issue. Are you the first original owner, and had registered it as appropriate? If yes, head to https://my.netgear.com/ , select your switch based on the serial number, and follow the process [Request Hardware Support] please
