Informatica
Sep 04, 2017Aspirant
JGS524v2 24 port - Loss of ethernet connection after 5-15 minutes
Hi, I have a switch that works perfectly fine after rebooting but 5-15 minutes later all wired connections simply stop working. So computer, printer, smart tv, etc all lose ethernet access. I also l...
- Sep 08, 2017
Hi informatica,
I would suggest that you disable the IGMP Snooping feature on the switch as all lights are green could be that a broadcast storm is happening in the network.
Hope it helps!
Regards
Xavier Lleixa
NETGEAR CBU PLM
Informatica
Sep 05, 2017Aspirant
Additional info:
1. Even when I cannot get internet, all ports are still green in the switch.
2. Changing from wired to wireless solve the problem for all the devices, i.e., there are no drops after 5-15 minutes.
3. I have performed factory reset in the switch.
4. Rebooting the switch solves the problems fir 5-15 minutes, after that I lose access to the internet and to the switch again.
i have no idea what else I can do.
thanks in advance for your help.
- InformaticaSep 05, 2017Aspirant
And the correct switch model is JGS524ev2 24port.
thanks
- XavierLLSep 08, 2017NETGEAR Employee Retired
Hi informatica,
Hope it helps!
Regards
Xavier Lleixa
NETGEAR CBU PLM
- InformaticaSep 12, 2017Aspirant
Hi,
thanks for the suggestion. Amazon replaced the switch and still had the same problem. I then took your suggestion and It worked! Big thank you.
I am now going to update the firmware with my fingers crossed.
take care
