Informatica
Sep 04, 2017Aspirant
JGS524v2 24 port - Loss of ethernet connection after 5-15 minutes
Hi, I have a switch that works perfectly fine after rebooting but 5-15 minutes later all wired connections simply stop working. So computer, printer, smart tv, etc all lose ethernet access. I also l...
- Sep 08, 2017
Hi informatica,
I would suggest that you disable the IGMP Snooping feature on the switch as all lights are green could be that a broadcast storm is happening in the network.
Hope it helps!
Regards
Xavier Lleixa
NETGEAR CBU PLM
Informatica
Sep 05, 2017Aspirant
Additional info:
1. Even when I cannot get internet, all ports are still green in the switch.
2. Changing from wired to wireless solve the problem for all the devices, i.e., there are no drops after 5-15 minutes.
3. I have performed factory reset in the switch.
4. Rebooting the switch solves the problems fir 5-15 minutes, after that I lose access to the internet and to the switch again.
i have no idea what else I can do.
thanks in advance for your help.
Informatica
And the correct switch model is JGS524ev2 24port.
thanks
- XavierLLSep 08, 2017NETGEAR Employee Retired
Hi informatica,
Hope it helps!
Regards
Xavier Lleixa
NETGEAR CBU PLM
- InformaticaSep 12, 2017Aspirant
Hi,
thanks for the suggestion. Amazon replaced the switch and still had the same problem. I then took your suggestion and It worked! Big thank you.
I am now going to update the firmware with my fingers crossed.
take care
- JohnC_VSep 13, 2017NETGEAR Employee Retired
Welcome to our community!
It seems that everything works ok now. I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
