dialsc
Jan 26, 2017Guide
Latest firmware (11.0.0.28) kills all switches
Hello, I just upgraded the firmware of all the M5300 switches we've got, stand alone as well as stacks. I was running version 11.0.0.25, a beta version I've got from Netgear support, on all of th...
LaurentMa
Jan 26, 2017NETGEAR Expert
Hi dialsc
Sorry for your issue here. We are trying to reproduce it in our labs with Tech Support teams and will report back here our findings.
dialsc
Jan 26, 2017Guide
Hi Laurent,
very nice, thanks. Let me know if I can be of any assistance to that.
Greez,
dialsc
- CaseyHJan 26, 2017NETGEAR Expert
Can you PM your tech-support file so I can reproduce this in the lab?
To get the tech-support file you need to:
1. console or telnet to your switch.
2. login
3. type "enable"
4. type "show tech-support"
5. Login to the GUI
6. goto "Maintenance\Upload\HTTP File Upload" and select "Tech Support" from the File type drop down box.
Thank you,
Casey
- dialscJan 26, 2017Guide
Hi,
right now I'm in the process of recovering our Hyper-V farm which totally crashed due to the switches rebooting...
Once I finished that I will seperate one switch, update the firmware and try to reproduce the problem. I will then do what you asked me to do.
Okay for you?
Greez,
dialsc
