ossalanr
Jan 22, 2016Tutor
LLDP "Operational MAU type" (802.3 TLV) is zero for GS724Tv3
Versions Model Name Boot Version Software Version B5.1.1.1 5.4.2.19 I've enabled the optional LLDP TLVs on all my ports. When I receive the 802....
ossalanr
Jan 26, 2016Tutor
I'm trying to use this in the Assimilation Suite - which maps host and network interconnections. Here's an example of how I'd like to use it:
If you look at this, I know the Duplex and MTU of the host-side of connections, but not the switch side. LLDP is supposed to provide this information from the switch side. Then I could validate the best practices here: http://assimilationsystems.com/2015/12/23/three-simple-network-best-practices/ For good measure, the MTU is not provided by this switch. The Maximum Frame Size TLV (Section G.5 in the spec) is not provided. I'd love to have both of these. The NICs are the red ovals. You can see that port eth0 is wired to port g6 on the switch. That is, the host's eth0 is plugged into the switch's g6 port.
ossalanr
Jan 28, 2016Tutor
It turns out that several of the LLDP-MED frames are also bogus.
Manufacturer: is "0xbc00" - should be "Netgear"
Hardware version is "0 0x0"
Firmware version is "rrr ttt"
Asset is "Asset 1717"
These are all ASCII (or perhaps UTF-8) strings.
They are all maximum length - with blanks filling out the length. The TLVs really ought to be the right length - although that's not a huge problem. Strangely enough, the hardware version string has the extra blanks after the "0" and before the "0x0".
On the plus side, the serial number, model and software version all look good.
I've now verified that three different switches that I own (including an 8-port model) have the same bugs.
I tried to attach a new picture like I did above, but something has changed in the interface, and I can't seem to do that any more.
- ossalanrJan 28, 2016Tutor
I now see why I couldn't post the picture - my login had expired. Now that I'm logged in again, here' s the picture I wanted to put in the link above.
In my code, I stripped any trailing blanks, but not those extra blanks in the middle of the strings. Like before, this data agrees with the results from Wireshark.
If the bogus data was replaced by real data, then this would be pretty cool. Note that it picks up the port description and puts it on the "g6" port description. If they fixed the speed and duplex and added the MTU value (mentioned at the start of this chain), then we could detect duplex and MTU mismatches. This would be pretty cool.
Lots of things are right here. It would be good to get the broken things fixed too. I've put in a request to get them fixed.
- ossalanrJan 30, 2016Tutor
I have three different Netgear switches - two are different models, with three different firmware levels. All three exhibit these bugs. Some of them don't support all those LLDP TLVs, but for those supported by a given level of firmware, they exhibit the same bug.
After getting all three properly registered , my complaint has been escalated to engineering. When Engineering comes back with a reply, I'll let you know how it goes here.
- ossalanrFeb 15, 2016Tutor
I'm told that engineering is still looking at my problem documentation.
In the meantime, you might enjoy this picture - it's a lot like the last one, but includes discovery of other IP/MAC pairs, and more information from DNS and IEEE OUIs:
All this is discovered automagically by the Assimilation Suite. This is a small subset of the graph we produce - but it includes most of the network-related pieces.
