smiya
May 20, 2019Aspirant
"Loop detected on interface" occurs despite different VLAN
I divided the VLAN by VLAN ID1 and VLAN ID2, but I set the VLAN of antaging by the access VLAN by the port which inserts LAN.
I set up port 1 (VLAN 1) and port 2 (VLAN 2) separately in connecti...
Retired_Member
May 20, 2019Hi smiya,
Suggest to configure MSTP based on VLAN, same setting on peer DELL switch, send us the configuration and we will help you review if you still see any issue.
- smiyaMay 20, 2019Aspirant
Thank you very much.
Disable STP on port 2 as it may only be blocked by STP prior to configuring MSTP.
If port 2 still does not connect, I would like to consider MSTP.
