smiya
May 20, 2019Aspirant
"Loop detected on interface" occurs despite different VLAN
I divided the VLAN by VLAN ID1 and VLAN ID2, but I set the VLAN of antaging by the access VLAN by the port which inserts LAN.
I set up port 1 (VLAN 1) and port 2 (VLAN 2) separately in connecti...
smiya
May 22, 2019Aspirant
Port 1 is untagged and VLAN 1 only.
Port 2 is untagged and VLAN 2 only.
It is recommended to set up MSTP.
Both port 1 and port 2 are different in VLAN.
You can see that if the same VLAN has two ports connected to the same switch, it loops.
What is the reason for detecting loops in different VLANs?
