cavtsupport
Nov 06, 2016Aspirant
Loss of connection to management interface
I have a Netgear FS728TP 24 port PoE switch that has been running for sometime now. The switch was setup with a static IP on my network for web management. The other day I tried to access the switc...
cavtsupport
Nov 15, 2016Aspirant
Dane,
After unplugging all of my devices I was able to get back into my switch. I have now been able to re-configure it back to my network settings and update the firmware.
This is the first time I have had to ever do this with a switch; thanks for the help.
Charles
DaneA
Nov 15, 2016NETGEAR Employee Retired
Hi cavtsupport,
You're welcome! :) I'm glad that you were able to access the management interface of the FS728TP and updated its firmware.
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,
DaneA
NETGEAR Community Team
