Nw_User
Jun 08, 2016Aspirant
Lowest cost smart or managed switch with console interface
Could someone recommend lowest cost smart or managed switch with console interface? I only need 4 ports but need to control over CLI, telnet or SSH.
- Retired_MemberJun 14, 2016no shutdown
Retired_Member
Jun 13, 2016telnet on port 60000
You don't get a prompt for the username, but type admin.
Then your password.
(Broadcom FASTPATH Switching) #show version
Switch: 1
System Description............................. GS108Tv2
Machine Type................................... GS108Tv2
Machine Model.................................. GS108T smartSwitch
Serial Number.................................. *****
FRU Number.....................................
Part Number.................................... BCM53312
Maintenance Level.............................. A
Manufacturer................................... 0xbc00
Burned In MAC Address.......................... *******
Software Version............................... 5.4.2.22
Operating System............................... ecos-2.0
Network Processing Device...................... BCM53312_B0
I was able to enter config mode and shutdown a port without problem.
I couldn't find an option to disable the service from the GUI, but you can very easily make an ACL if necessary.
Nw_User
Jun 13, 2016Aspirant
Hi jak0lantash,
Can I use GS108T with one port with static IP address 192.168.0.xxx and another port with DHCP? Or do I need to break on different VLANs?
Thanks.
