Nw_User
Jun 08, 2016Aspirant
Lowest cost smart or managed switch with console interface
Could someone recommend lowest cost smart or managed switch with console interface? I only need 4 ports but need to control over CLI, telnet or SSH.
- Retired_MemberJun 14, 2016no shutdown
Retired_Member
Jun 14, 2016You need to go into "enable" mode.
Type "enable", no password, hit Enter
- Nw_UserJun 14, 2016Aspirant
Thanks jak0lantash!
Got it . . . it works!
Which command do I use to disable or shutdown port7?
Thanks again.
