ecanales
Jan 05, 2017Aspirant
M400-26G Firmware update
Regarding swith M400-26G what the improvemets between firmware 10.0.1.16 and 10.0.2.13 are?
- Jan 05, 2017
Hi ecanales,
Any technical paper for bugs and new features we have are posted on the release notes. Since there is a big gap between the firmware versions, I'll just list down every bug fix for each firmware. See them below:
10.0.1.21
- No bug fix but has additional features.
10.0.1.27
- Boot code doesn't load backup image when the primary image is corrupted
- CLI command unable to apply include/exclude to VLAN 2 after voice VLAN changed to other VLANID
- The maximum number of routing interfaces is incorrect
- Cannot change VLAN 2's name
- Fiber port doesn't link up with ASUS switch using AGM731F with auto-negotiation mode
- Script list command not showing correct date time according to system clock, and not updating timestamp when time zone changed
- Vendor ID is incorrect for RADIUS commands authorization
- MAC Authentication Bypass issue if RADIUS server is using EAP-TLS
- POE switch rebooted itself when certain IP phone is connected and the port is in 802.1x mode
- The switch message log is flooded with VOIP messages
- LAG port to other switch does not come up automatically after the switch is rebooted
- Add crash dump log to tech-support file
- Unable to setup DHCP pool with option 42
- System log shows NIM out of bounds error messages
- CLI command, 'show fiber-ports' cannot show the 100FX SFP AFM735's information
10.0.1.28
- Cable test sometimes shows 'cable status test failed’ on port that does not have cable attached
- Some POE cameras keep rebooting in an endless loop
- Disconnects from RADIUS Server if client did not update its 802.1x status in timely manner
- Sometimes system log buffer records a lot of messages from NIM module
- DHCP pool name and option string is limited to 15 on the GUI while CLI allows 255
- Console hung after session timeout when TACACS accounting is in use
- Cannot set "radius" as the method in "aaa accounting command" as RADIUS is not supported. RADIUS option removed.
10.0.2.11
- No bug fix but with new features and enhancements
10.0.2.13
- Fixed the issue where EZCONFIG is not working on firmware 10.0.2.11
- Fixed the issue where 'show network' doesn’t show the IP address for the management VLAN.
- Since 10.0.2.11, ‘show network’ shows the IP address for management VLAN. But if user specifies an IP address on previous 10.0 image and then upgrade it to 10.0.2.11, this command will show the IP address for the network interface.
- Added some restrictions and changes
If you are planning to do an update, please take note that we advise to perform the update incrementally.
Thanks,
ecanales
Hello John,
Thank you for your message.
Please, could you give me more details about the bug fixed? or you can share any technical paper regarding it...Definitely, the firmware version (10.0.1.16) that I have is older.
Ernesto C.
JohnRo
Jan 05, 2017NETGEAR Employee Retired
Hi ecanales,
10.0.1.21
10.0.1.27
10.0.1.28
10.0.2.11
10.0.2.13
Thanks,
