Thoranium
Oct 11, 2017Follower
M4100-26G GSM7224v2h2 Letter of Volatility Request
I need a letter of volatility for the M4100-26G GSM7224v2h2 switch. On a side note, I searched for letter of volatility in the community and all "solved" solutions have dead links to the files. A...
DaneA
Oct 12, 2017NETGEAR Employee Retired
Hello Thoranium,
Welcome to the community! :)
You can download the Letter of Volatility of the M4100-26G (GSM7224v2h2) switch on this link. The link will expire within 48 hours.
DaneA
NETGEAR Community Team
DaneA
Oct 15, 2017NETGEAR Employee Retired
I just want to follow-up on this. Were you able to download the Letter of Volatility of the M4100-26G (GSM7224v2h2) switch?
If ever you were able to download it and you have no further inquiries, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,
DaneA
