JOnline76
Sep 16, 2018Aspirant
M4100-26G-POE switch Time Schedule Configuration - Cannot set Start and Stop times
No matter what I choose in the UI to set a Time Schedule the UI tells me it cannot set the Start and Stop Time.
I am attempting to set a Periodic Schedule.
To start at 03:00
To end at 0...
- Sep 26, 2018
I was able to figure out what I was doing wrong:
The problem was that I was selecting the "Current day", for example, September 26th, for today, and the schedule was for 0300 (3AM). Beceause that time had already passed the system was rejecting my addition of the schedule.
The error message could be a bit more descriptive than what it is. Ideally, the system would still allow me to set it and just ignore that the first time had already passed.
DaneA
Sep 24, 2018NETGEAR Employee Retired
I got a feedback from the higher tier of NETGEAR Support with regard to your concern. As per the higher tier of NETGEAR Support, they were able to configure the Time Schedule using an M4100-24G-PoE+ switch using firmware v10.0.2.26 with the exact settings you have defined as per the image you have attached on your initial post and were not able to reproduce the issue you have encountered.
Kindly send me the config file of your M4100 switch via private message for further testing. Be sure to provide the admin password in order for us to gain access and check the settings. You may provide a download link (via Google Drive or Dropbox) so that I can download it here on my end.
DaneA
NETGEAR Community Team
JOnline76
Sep 26, 2018Aspirant
