Kwang's avatar
Kwang
M4100-26G Port occurred repeat UP/Down
Hi   Machin Model : M4100-26G Software Version : 10.0.2.13 Bootcode Version : B1.0.1.1   occurred repeat This below message, why occurred this issue?   <13> Apr 24 13:51:25 XXX.XXX.XX...
  • JohnC_V's avatar
    Apr 26, 2019
    Hi Kwang,
    Welcome to our community! :)
    It seems that the device connected to port 24 is going up and down. May I know the device connected to this port? May you be able to attach or send the logs via pm so that we can check if there is anything out of the ordinary that happens to port 24 before this. If nothing happened in the logs, then you can try swapping out the cable.
    JohnCarloV
    NETGEAR Community Team
ProSupport for Business
