Asunnyday
Mar 02, 2018Follower
M4100 26g won't let me log in via console after reset?
I would like to factory reset my switch. I have connected to switch via the console port and can get to the point where it asks for "User:" According the the online literature the User = admi...
DaneA
Mar 05, 2018NETGEAR Employee Retired
The reset button at the front panel of the M4100-26G switch just reboots the switch.
Since you wanted to reset the M4100-26G switch to factory default settings, kindly access the article below:
M4100: Boot Menu - read the section about Accessing the Boot Menu on M4100 and Factory Default the Switch
Another option: If ever you are still able to access the web-GUI of the M4100-26G switch, go to Maintenance > Reset > Factory Default then select the check box and click the APPLY button. As reference, read pages 407-408 of the M4100 user manual here on how to Reset the Switch to Factory Default Settings using the web-GUI.
DaneA
NETGEAR Community Team
- DaneAMar 08, 2018NETGEAR Employee Retired
I just want to follow-up on this. We’d greatly appreciate your feedback.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
