Cochones8
Nov 29, 2019Aspirant
M4100-50g bought used, need factory reset, have no IP Adress, no login data
Hi I bougt a used M410050G from a corporate insolvency. I added it to a existing system of 3 GS724T. Now not all of the Ports on the 4100 work - so i think its a confeiguration problem...maybe th...
- Dec 08, 2019
Ah - it's a boot menu, power-off the switch, it will only show up after power-on at boot time obviously.
schumaku
Nov 30, 2019Guru - Experienced User
Cochones8
Nov 30, 2019Aspirant
Thank you for the reply.
But how can i reach that boot menu without having the ip of the switch? I ran ipscans for hours already...
- schumakuNov 30, 2019Guru - Experienced User
Not by IP in this status, serial line console -> How to access the command line interface using the console ports of M4100, M4200, M4300, M5300 and M7100 series switches
