nsskyetech
Feb 27, 2017Aspirant
M4100-50G-POE+ sFlow
Hello All; M4100-50G-POE+ ProSafe 48-port Gigabit L2+ Intelligent Edge PoE Managed Switch, 10.0.1.16, B1.0.0.9 Trying to setup sFlow with PRTG. Has any one don this. When I setup the M4100 ...
DanielZhang
Feb 27, 2017NETGEAR Expert
Hi Nsskyetech,
Welcome to NETGEAR community!
Maybe some configuration missing in your topology.
You can find the configuration guide form the user manual as following link:
I also have a sFlow configuration on M4100 as below:
Please check and compare with yours.
(M4100-26G) #show sflow agent
sFlow Version.................................. 1.3;Netgear Inc.;10.0.2.13
IP Address..................................... 100.1.1.99 -->>this IP address used for agent .
(M4100-26G) #show ip interface brief
Interface State IP Address IP Mask Method
vlan 1 Up 100.1.1.99 255.255.255.0 Manual --->>this VLAN interface used for sFlow agent.
(M4100-26G) #show sflow source-interface
sFlow Client Source Interface.................. vlan 1
sFlow Client Source IPv4 Address............... 100.1.1.99 [Up] --->>this Source interface used for sFlow agent.(make sure the source interface could communicate with receiver)
(M4100-26G) #
(M4100-26G) #show sflow receivers
Rcvr Owner Timeout Max Dgram Port IP Address
Indx String Size
1 0 1400 6343 0.0.0.0
2 0 1400 6343 0.0.0.0
3 0 1400 6343 0.0.0.0
4 0 1400 6343 0.0.0.0
5 0 1400 6343 0.0.0.0
6 0 1400 6343 0.0.0.0
7 0 1400 6343 0.0.0.0
8 100.1.1.154 No Timeout 1400 6343 100.1.1.154 --->>this IP address used for receiver #8 just like your PRTG.
(M4100-26G) #show sflow samplers
Sampler Receiver Packet Max Header
Data Source Index Sampling Rate Size
0/1 8 1024 128
0/3 8 1024 128 --->assign sample with receiver's index #8 on the ports which you want to monitor.
0/4 8 1024 128
0/5 8 1024 128
0/6 8 1024 128
0/7 8 1024 128
0/8 8 1024 128
You can find more useful information from the user manual.
It will help you setup sFlow
May the solution help you.
- nsskyetechMar 01, 2017Aspirant
Thank you for the Info.
I do not have a vlan on this switch, so should the 'show ip interface brief' display anything?
I thin it should and ith should have the IP address of the switch, right?
(M4100-50G-POE+) #
(M4100-50G-POE+) #show ip interface brief
---------- ----- --------------- --------------- -------Also the source-interface is blank. I see no command either in the CLI reference or the Web interface to set this. How can this be set?
(M4100-50G-POE+) #show sflow source-interface
sFlow Client Source Interface.................. (not configured)- DanielZhangMar 01, 2017NETGEAR Expert
Hi nsskyetech,
Yes.
We need a IP address to run this function between agent and receiver.
We need to setup a VLAN or physical routing interface with IP address for sFlow.
So please check the connection between M4100 and PRTG.
(such as:
1.Ping M4100 from PRTG. (Do next step if Ping is OK.)
2.Capture packets on PRTG network adapter filter with the IP address which used for M4100.(Do next step if sFlow packets received on PRTG)
3.Check PRTG software configuration.(please check software manual of PRTG)
Please backup the configuration file on M4100 before the next operation.
1.Save configuration.
2.Upload configuration to PC or MAC.
You can also upgrade M4100 to 10.0.2.x and then do a factory reset before deploy sFlow configuration.
It will make a VLAN interface that used for management interface also work with sFlow.
