Gerry_D
Feb 22, 2019Star
M4100-D12G Clear RAM and disable DHCP.
OK, here goes nothing...
Realize this, it's been about 20 years since I had a course in Routers, Bridges and Switches. I've been retired from that job for 11 years, presently just repairing slot ma...
- Feb 28, 2019
As a managed switch, it requires a IP configuration - either from a DHCP server (thus DHCP enabled) or by deploying a static IP config.
Consult the nice documentation - e.g. the User Manual ref. the Factory Reset https://www.netgear.com/support/product/m4100-d12g%20(gsm5212v1h1).aspx#docs
schumaku
Feb 28, 2019Guru - Experienced User
Gerry_D
Feb 28, 2019Star
Thanks, I got it done before your reply, but could not find my original request on here to say I got it done.
I fortunately had a copy of "PuTTY" to communicate via USB tocresaet User, Password and assign an IP address. After that it was a cinch with the menu system and html interface.
Thanks Just the same!
Cordially,
Mounted on the side of my desk in the basement.Gerry
