Budgie4
May 18, 2020Tutor
M4100-D12G Managed Switch Bridged Pair with 3 subnets
Hi, I have 2 of the captioned switches working over a bridge link with Vlan trunking of 3 subnets. All work well but, to date and for WiFi I have used a separate WiFi AP connected to the subnet por...
schumaku
May 18, 2020Guru - Experienced User
Typical solution is having dedicated VLANs for each IP subnet, and configure a VLAN trunk for the connection to the undefind Wireless AP, either run the primary VLAN and/or management VLAN [U]natgged and all other VLAN [T]agged, or configure all VLANs [T]agged.
Budgie4
May 23, 2020Tutor
I have it now thanks setting up a trunk for the port which feeds the AP. Will do this for all the rest.
I did have a problem with the AP devices as L2 isolation had been set on all SSIDs. My mistake but will nead to read up on configuring management VLan correctly for all devices so I can connect to all of them, switches, APs and Router.
Is the correct practice to set up a management subnet and putting all devices to have static IPs on that subnet?
Your guidancemuch appreciated, thanks again,
Budgie4
