paulswansea
Sep 27, 2018Initiate
M4100-D12G-POE+ Firmware Upgrade Kills POE
I've tried several times to upgrade Firmware Version 10.0.2.13 to Firmware Version 10.0.2.26, but every time I have attempted, there is no longer any Power over Ethernet, even after doing a 'factory ...
- Sep 28, 2018
Hi paulswansea,
Welcome to our community! :)
It seems that you encountered an issue regarding the firmware that the POE doesn't work at all right after the upgrade. Please try to upgrade it first to firmware v10.0.2.20 before upgrading it to v10.0.2.26. If it still didn't work then I suggest you to open a chat / case online on NETGEAR support and please let them know the status of your switch. This case might be escalated to the engineering team for further investigation.
JohnC_V
Sep 28, 2018NETGEAR Employee Retired
Hi paulswansea,
