patroskam
Aug 08, 2017Aspirant
M4100-D12G-POE+ managment IP config not working
So we are trying to impliment this switch and went through the CLI ezconfig, and through the web interface with factory reset in between each since neither worked. The IP that I entered shows up as ...
Hopchen
Aug 08, 2017Prodigy
Hi,
Is your PC in the same subnet as the IP you give the switch?
What IP did you give the switch? What IP is on your PC?
From the CLI, forget ezconfig :) Just do:
enable (to enable the switch)
configure (to get into configure mode)
interface vlan 1 (to get into sub interface mode)
ip address 192.168.1.254 255.255.255.0 (or whatever IP+mask you want)
Then access the switch GUI on that IP.
Cheers
- patroskamAug 08, 2017Aspirant
Thanks so much for the quick response!
My IP info is 192.168.10.100 255.255.255.0
I just ran the commands you sent in the CLI and I still cannot connect.
- HopchenAug 08, 2017Prodigy
Hi,
I can't see the picture/screenshot yet. I assume Netgear must validate it first.
Your pc had IP: 192.168.10.100?
What IP did you give the switch exactly?
- Retired_MemberAug 09, 2017
Hi patroskam,
According to your configuration, you want to use VLAN 100 as Management VLAN, right?
So please add the port(connect to PC) untagged to VLAN 100, and set PVID to 100. Then try again.
As your command 'show network' output display that the network is down, so PC cannot access to the Switch.
