garyroute
Mar 21, 2017Tutor
M4100 IGMP Snooping
Hi I have multicast set up on an M4100 and a GS110TP interconnected with a link and with both using VLAN 3. All works well with having multiple muticast streams running between the switches. The Que...
- Apr 23, 2017
Good News!
After receiving your email today I decided to take another look at the configs of the M1400 and GS11TPs. I had wondered about the muticast router configs so I enabled Multicast Router and Multicast VLAN Router on port 10 of the GS110TP. Now everything works great. It only takes 2 or 3 seconds to start a stream and other issues have also been resolved. Below is the network diagram showing the Multicast configs. I assume that the Querier running on the M1400 is the Multicast router.
Thanks Gary
DaneA
Mar 23, 2017NETGEAR Employee Retired
Hi garyroute,
Welcome to the community! :)
Kindly post screenshots of the configuration about IGMP Snooping on the M4100 and GS110TP switches as well as a diagram of your detailed network setup.
What is the current firmware version of the M4100 and GS110TP switches?
Let me share this article I found online and it might help as a guide.
DaneA
NETGEAR Community Team
