garyroute's avatar
Mar 21, 2017
M4100 IGMP Snooping
Hi I have multicast set up on an M4100 and a GS110TP interconnected with a link and with both using VLAN 3. All works well with having multiple muticast streams running between the switches. The Que...
  • garyroute's avatar
    garyroute
    Apr 23, 2017
    Good News!
    After receiving your email today I decided to take another look at the configs of the M1400 and GS11TPs. I had wondered about the muticast router configs so I enabled Multicast Router and Multicast VLAN Router on port 10 of the GS110TP. Now everything works great. It only takes 2 or 3 seconds to start a stream and other issues have also been resolved. Below is the network diagram showing the Multicast configs. I assume that the Querier running on the M1400 is the Multicast router.
ProSupport for Business
