garyroute
Mar 21, 2017Tutor
M4100 IGMP Snooping
Hi I have multicast set up on an M4100 and a GS110TP interconnected with a link and with both using VLAN 3. All works well with having multiple muticast streams running between the switches. The Que...
- Apr 23, 2017
Good News!
After receiving your email today I decided to take another look at the configs of the M1400 and GS11TPs. I had wondered about the muticast router configs so I enabled Multicast Router and Multicast VLAN Router on port 10 of the GS110TP. Now everything works great. It only takes 2 or 3 seconds to start a stream and other issues have also been resolved. Below is the network diagram showing the Multicast configs. I assume that the Querier running on the M1400 is the Multicast router.
Thanks Gary
DaneA
Apr 23, 2017NETGEAR Employee Retired
I apologize again for this is the only time I got back on this. I have inquired again your concern to a higher tier of NETGEAR Support.
It was advised that it would be best if you will open a chat / online case with NETGEAR Support. Let them know about your concern and it might get escalated to the engineering team for further investigation.
DaneA
NETGEAR Community Team
garyroute
Apr 23, 2017Tutor
Good News!
Thanks Gary
- DaneAApr 24, 2017NETGEAR Employee Retired
That's great! :) I'm glad to know that you were able to figure it out.
Since you were able to resolve the problem, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
