Luke_M
Oct 25, 2018Aspirant
M4100 will not write to memory
I have a M4100 That will not save and configuration changes.
(M4100-24G-POE+) #write memory This operation may take a few minutes. Management interfaces will not be available during this time. Are you sure you want to save? (y/n) Y Config file 'startup-config' created successfully . Configuration Not Saved! (M4100-24G-POE+) #
I have also tried ezconfig, no matter what chantes i make the end is "
Configuration Not Saved!"
- Luke_MAspirant
I don't see an edit button, so here is some more info
(M4100-24G-POE+) #erase ? factory-defaults Erase the text-based factory-defaults file stored in non-volatile memory. startup-config Erase the text-based configuration file stored in non-volatile memory. (M4100-24G-POE+) #erase startup-config Are you sure you want to clear the configuration? (y/n)y Error! Couldn't erase startup-config file. (M4100-24G-POE+) #erase factory-defaults Are you sure you want to delete the factory-defaults file? (y/n)y Error! Couldn't erase factory-defaults file.
I've also tried to boot the other firmware stored on the box.
(M4100-24G-POE+) #show bootvar Image Descriptions image1 : image2 : Images currently available on Flash ---- ---------- ---------- ----------------- ----------------- unit image1 image2 current-active next-active ---- ---------- ---------- ----------------- ----------------- 1 10.0.2.26 10.0.2.20 image2 image2
- JohnC_VNETGEAR Employee Retired
Hi Luke_M,
Welcome to our community! :)
May you be able to try "save" or "copy running-config startup-config" to see if it will produce the same result? I will also inquire this case but it seems that the memory is corrupted.
- Luke_MAspirant
Thanks for the effort, but I get the same stuff.
(M4100-24G-POE+) >enable (M4100-24G-POE+) #save This operation may take a few minutes. Management interfaces will not be available during this time. Are you sure you want to save? (y/n) y Config file 'startup-config' created successfully . Configuration Not Saved! (M4100-24G-POE+) #copy system:running-config nvram:startup-config This operation may take a few minutes. Management interfaces will not be available during this time. Are you sure you want to save? (y/n) Y # Config file 'startup-config' created successfully . Configuration Not Saved!
I suggest you to back-up the configuration file then reset the switch to factory default. Let's see if saving will work on default configuration.
- Luke_MAspirant
I'll try that on monday so I have clear logs to in case of my error, but I have done that.
The currnet config I have is blank, its essentially and unmanged switch right now.
- Luke_MAspirant
Is there another wat to erase?
M4100-24G-POE+) #erase startup-config ? <cr> Press enter to execute the command. (M4100-24G-POE+) #erase startup-config Are you sure you want to clear the configuration? (y/n)y Error! Couldn't erase startup-config file. (M4100-24G-POE+) #
(M4100-24G-POE+) #erase factory-defaults Are you sure you want to delete the factory-defaults file? (y/n)y Error! Couldn't erase factory-defaults file. (M4100-24G-POE+) #
The flash might be corrupted that is why you cannot save anything. I suggest you to open a ticket on NETGEAR support and please let them know the status of the switch. Please be ready with a soft copy of the Proof of Purchase or Invoice of the device for warranty verification. If ever the device is still under warranty, an online replacement will be provided.
Here is our warranty policy.
