pieterjanheyse
Jan 26, 2018Aspirant
M4300 - M4100 and GVRP
I have a couple of M4300 switches acting as a new core stack, and using M4100 as distribution switches. Instead of manually configuring VLANs on all of the M4100 switches, I figured I'd use the GVRP ...
- Jan 29, 2018
Hi pieterjanheyse,
Kindly try to set the VLAN Type from Dynamic to Static then try to modify the settings you prefer. Check if it helps.
DaneA
NETGEAR Community Team
DaneA
Jan 29, 2018NETGEAR Employee Retired
Hi pieterjanheyse,
DaneA
