joeyang
Sep 11, 2019Aspirant
M4300-12x12f port aggregation with IP routing
Hello All, Recently I have setup a network for my client with our storage solution. I have 2 M4300 12x12F stacked together. Currently i have 2 ports, one from unit 1 one from unit 2, connected to...
Retired_Member
Sep 16, 2019Hi joeyang
Welcome to Community!
Is your 2 Cisco N7K stacking? If so, you can create LAG with the 2 ports. If not, only one side(M4300) is stacking, then the LAG will not work if you bind the 2 ports to one LAG.
Hope it helps!
EricZ
- joeyangSep 19, 2019Aspirant
Hello Ericz,
Thank you for your reply. I am not so sure if they are stacked. I will have to confirm with them. Cisco team informed me that they can create a port channel with 2 ports and assign it with a IP address to communicate with our switch but I can't seem to do so on the Netgear. I can only assign IP address to single port. We have layer 3 network setup between Cisco and Netgear now.
Best Regards,
