ecalore
Feb 07, 2025Aspirant
M4300-12X12F strange behavior when using Dell LTF8502-BC+-DEN1 10Gb/s SFP+ modules
Hi, I recently added to our Netgear M4300-12X12F switch (Firmware 12.0.19.4, AV UI Version 2.2.8.26, Boot Version B1.0.0.17) some Dell LTF8502-BC+-DEN1 SFP+ transceivers, right after doing that...
schumaku
Feb 11, 2025Guru - Experienced User
Connect a serial console (e.g. a PC with a terminal program) via the [supplied] USB2serial adapter, and capture all the output 24*7, including the potential crash and restart, of course while your third-party modules are in place and active.
Keep in mind Netgear does not support third-party SFP/SFP+ modules. Double check if the same problem happens while operting original Netgear modules.
- ecaloreFeb 12, 2025Aspirant
Hi,
actually the problem happens as soon as the Dell Transceiver is inserted in a slot, thus I guess that few minutes of logs are enough.
Here is the output of the "show fiber-ports optics-info all" command without the Dell transceiver, when the switch seems to be in a perfectly working condition.
Then I enable the console logging and insert the Dell transceiver. As soon as this kind of transceiver is inserted (I tested several of them with the same results), several error events get into the console and eventually the switch reboots.
After the transceiver is removed, the switch need to be manually rebooted in order to be fully functional again.
(M4300-12X12F) #show fiber-ports optics-info all
Link Link Nominal
Length Length Link Bit Possible
50um 62.5um Length Rate Speed
Port Vendor Name [m] [m] [m] Serial Number Part Number [Mbps] Rev Compliance Supported Detected
1/0/1 NETGEAR 8 3 - 3V819C5300630 AXM761 10300 3000 10GBase-SR Yes 10G
1/0/2 NETGEAR 8 3 - 3V819C5700561 AXM761 10300 3000 10GBase-SR Yes 10G
1/0/3 NETGEAR 8 3 - 3V819C5D00559 AXM761 10300 3000 10GBase-SR Yes 10G
1/0/4 NETGEAR 8 3 - 3V81565C01ADF AXM761 10300 3000 10GBase-SR Yes 10G
1/0/5 MicroOptics 8 3 - STCO85SA4400827 MO-AXM761-10000S 10300 A 10GBase-SR Yes 10G
1/0/6 NETGEAR 8 3 - 3V819C5700553 AXM761 10300 3000 10GBase-SR Yes 10G
(M4300-12X12F) #config
(M4300-12X12F) (Config)#logging console
<10> Feb 12 15:12:07 192.168.0.239-1 General[intDisTask]: cpu_boxs.c(2197) 694 %% Event(0x5c000001)
<10> Feb 12 15:12:07 192.168.0.239-1 General[intDisTask]: cpu_boxs.c(2197) 704 %% Event(0x5c000001)
<10> Feb 12 15:12:07 192.168.0.239-1 General[intDisTask]: cpu_boxs.c(2215) 706 %% Event(0x5c000002)
<10> Feb 12 15:12:07 192.168.0.239-1 General[intDisTask]: cpu_boxs.c(2197) 709 %% Event(0x5c000001)
<10> Feb 12 15:12:07 192.168.0.239-1 General[intDisTask]: cpu_boxs.c(2197) 716 %% Event(0x5c000001)
<10> Feb 12 15:12:08 192.168.0.239-1 General[intDisTask]: cpu_boxs.c(2197) 720 %% Event(0x5c000001)
<8> Feb 12 15:12:08 192.168.0.239-1 BSP[intDisTask]: cpu_utils.c(1321) 722 %% CPLD(0x30): Unable to write data(0x2b)@reg(0x02).
<10> Feb 12 15:12:08 192.168.0.239-1 General[intDisTask]: cpu_boxs.c(2197) 732 %% Event(0x5c000001)
<10> Feb 12 15:12:08 192.168.0.239-1 General[intDisTask]: cpu_boxs.c(2215) 734 %% Event(0x5c000002)
<10> Feb 12 15:12:08 192.168.0.239-1 General[intDisTask]: cpu_boxs.c(2197) 737 %% Event(0x5c000001)... A lot of same error events and then:
<10> Feb 12 15:12:14 192.168.0.239-1 General[intDisTask]: cpu_boxs.c(2215) 1074 %% Event(0x5c000002)
<10> Feb 12 15:12:14 192.168.0.239-1 General[intDisTask]: cpu_boxs.c(2197) 1079 %% Event(0x5c000001)
<11> Feb 12 15:12:17 192.168.0.239-1 BOXSERV[boxs Req]: boxs.c(1365) 1102 %% Unit 1 fan 2 FAILURE event (4) occurred.
<11> Feb 12 15:12:31 192.168.0.239-1 BOXSERV[boxs Req]: boxs.c(1365) 1167 %% Unit 1 fan 1 FAILURE event (4) occurred.
<11> Feb 12 15:12:34 192.168.0.239-1 BOXSERV[boxs Req]: boxs.c(1365) 1195 %% Unit 1 fan 2 FAILURE event (4) occurred.
<11> Feb 12 15:12:37 192.168.0.239-1 BOXSERV[boxs Req]: boxs.c(1365) 1203 %% Unit 1 fan 1 FAILURE event (4) occurred.
<11> Feb 12 15:12:41 192.168.0.239-1 BOXSERV[boxs Req]: boxs.c(1452) 1223 %% Unit 1 power supply 1 FAILURE event (4) occurred.
<11> Feb 12 15:12:44 192.168.0.239-1 BOXSERV[boxs Req]: boxs.c(1365) 1239 %% Unit 1 fan 2 FAILURE event (4) occurred.
<11> Feb 12 15:12:44 192.168.0.239-1 NIM[boxs Req]: nim_util.c(1568) 1244 %% NIM: intIfNum out of range
<11> Feb 12 15:12:55 192.168.0.239-1 BOXSERV[boxs Req]: boxs.c(1365) 1292 %% Unit 1 fan 1 FAILURE event (4) occurred.
<11> Feb 12 15:13:16 192.168.0.239-1 BOXSERV[boxs Req]: boxs.c(1365) 1371 %% Unit 1 fan 2 FAILURE event (4) occurred.
*** IDLE TIMEOUT ***
User:
<11> Feb 12 15:13:26 192.168.0.239-1 BOXSERV[boxs Req]: boxs.c(1365) 1410 %% Unit 1 fan 2 FAILURE event (4) occurred.
<11> Feb 12 15:13:29 192.168.0.239-1 NIM[boxs Req]: nim_util.c(1568) 1448 %% NIM: intIfNum out of range
<11> Feb 12 15:13:42 192.168.0.239-1 BOXSERV[boxs Req]: boxs.c(1365) 1500 %% Unit 1 fan 2 FAILURE event (4) occurred.
<11> Feb 12 15:13:46 192.168.0.239-1 BOXSERV[boxs Req]: boxs.c(1365) 1529 %% Unit 1 fan 1 FAILURE event (4) occurred.
<11> Feb 12 15:14:03 192.168.0.239-1 BOXSERV[boxs Req]: boxs.c(1365) 1604 %% Unit 1 fan 2 FAILURE event (4) occurred.
<11> Feb 12 15:14:20 192.168.0.239-1 BOXSERV[boxs Req]: boxs.c(1365) 1686 %% Unit 1 fan 1 FAILURE event (4) occurred.
<11> Feb 12 15:14:20 192.168.0.239-1 BOXSERV[boxs Req]: boxs.c(1365) 1688 %% Unit 1 fan 2 FAILURE event (4) occurred.
<8> Feb 12 15:14:25 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1728 %% CPLD(0x30): Unable to read reg(0x50).
<8> Feb 12 15:14:25 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1729 %% CPLD(0x30): Unable to read reg(0x02).
<8> Feb 12 15:14:25 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1321) 1730 %% CPLD(0x30): Unable to write data(0xa5)@reg(0x02).
<8> Feb 12 15:14:25 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1731 %% CPLD(0x30): Unable to read reg(0x10).
<8> Feb 12 15:14:25 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1732 %% CPLD(0x30): Unable to read reg(0x11).
<8> Feb 12 15:14:25 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1733 %% CPLD(0x30): Unable to read reg(0x19).
<8> Feb 12 15:14:25 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1734 %% CPLD(0x30): Unable to read reg(0x1a).
<8> Feb 12 15:14:25 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1737 %% CPLD(0x30): Unable to read reg(0x02).
<8> Feb 12 15:14:25 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1321) 1738 %% CPLD(0x30): Unable to write data(0x00)@reg(0x02).
<8> Feb 12 15:14:27 192.168.0.239-1 BSP[boxs Req]: cpu_utils.c(1293) 1739 %% CPLD(0x30): Unable to read reg(0x50).
<8> Feb 12 15:14:29 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1741 %% CPLD(0x30): Unable to read reg(0x50).
<8> Feb 12 15:14:29 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1742 %% CPLD(0x30): Unable to read reg(0x02).
<8> Feb 12 15:14:29 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1321) 1743 %% CPLD(0x30): Unable to write data(0xa5)@reg(0x02).
<11> Feb 12 15:14:29 192.168.0.239-1 BOXSERV[boxs Req]: boxs.c(1365) 1745 %% Unit 1 fan 1 FAILURE event (4) occurred.
<11> Feb 12 15:14:29 192.168.0.239-1 BOXSERV[boxs Req]: boxs.c(1365) 1747 %% Unit 1 fan 2 FAILURE event (4) occurred.
<11> Feb 12 15:14:29 192.168.0.239-1 BOXSERV[boxs Req]: boxs.c(1452) 1749 %% Unit 1 power supply 1 FAILURE event (4) occurred.
<8> Feb 12 15:14:29 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1751 %% CPLD(0x30): Unable to read reg(0x10).
<8> Feb 12 15:14:29 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1752 %% CPLD(0x30): Unable to read reg(0x11).
<8> Feb 12 15:14:29 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1753 %% CPLD(0x30): Unable to read reg(0x19).
<8> Feb 12 15:14:29 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1754 %% CPLD(0x30): Unable to read reg(0x1a).
<8> Feb 12 15:14:29 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1757 %% CPLD(0x30): Unable to read reg(0x02).
<8> Feb 12 15:14:29 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1321) 1758 %% CPLD(0x30): Unable to write data(0x00)@reg(0x02).
<8> Feb 12 15:14:32 192.168.0.239-1 BSP[boxs Req]: cpu_utils.c(1293) 1759 %% CPLD(0x30): Unable to read reg(0x50).
<8> Feb 12 15:14:33 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1760 %% CPLD(0x30): Unable to read reg(0x50).
<8> Feb 12 15:14:33 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1761 %% CPLD(0x30): Unable to read reg(0x02).
<8> Feb 12 15:14:33 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1321) 1762 %% CPLD(0x30): Unable to write data(0xa5)@reg(0x02).
<8> Feb 12 15:14:34 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1763 %% CPLD(0x30): Unable to read reg(0x10).
<8> Feb 12 15:14:34 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1764 %% CPLD(0x30): Unable to read reg(0x11).
<8> Feb 12 15:14:34 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1765 %% CPLD(0x30): Unable to read reg(0x19).
<8> Feb 12 15:14:34 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1766 %% CPLD(0x30): Unable to read reg(0x1a).
<8> Feb 12 15:14:34 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1769 %% CPLD(0x30): Unable to read reg(0x02).
<8> Feb 12 15:14:34 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1321) 1770 %% CPLD(0x30): Unable to write data(0x00)@reg(0x02).
<8> Feb 12 15:14:38 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1773 %% CPLD(0x30): Unable to read reg(0x50).
<8> Feb 12 15:14:38 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1774 %% CPLD(0x30): Unable to read reg(0x02).
<8> Feb 12 15:14:38 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1321) 1775 %% CPLD(0x30): Unable to write data(0xa5)@reg(0x02).
<8> Feb 12 15:14:38 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1776 %% CPLD(0x30): Unable to read reg(0x10).
<8> Feb 12 15:14:38 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1777 %% CPLD(0x30): Unable to read reg(0x11).
<8> Feb 12 15:14:38 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1778 %% CPLD(0x30): Unable to read reg(0x19).
<8> Feb 12 15:14:38 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1779 %% CPLD(0x30): Unable to read reg(0x1a).
<8> Feb 12 15:14:38 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1782 %% CPLD(0x30): Unable to read reg(0x02).
<8> Feb 12 15:14:38 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1321) 1783 %% CPLD(0x30): Unable to write data(0x00)@reg(0x02).
<8> Feb 12 15:14:38 192.168.0.239-1 BSP[boxs Req]: cpu_utils.c(1293) 1784 %% CPLD(0x30): Unable to read reg(0x50).
<8> Feb 12 15:14:42 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1787 %% CPLD(0x30): Unable to read reg(0x50).
<8> Feb 12 15:14:42 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1788 %% CPLD(0x30): Unable to read reg(0x02).
<8> Feb 12 15:14:42 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1321) 1789 %% CPLD(0x30): Unable to write data(0xa5)@reg(0x02).
<8> Feb 12 15:14:42 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1790 %% CPLD(0x30): Unable to read reg(0x10).
<8> Feb 12 15:14:42 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1791 %% CPLD(0x30): Unable to read reg(0x11).
<8> Feb 12 15:14:42 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1792 %% CPLD(0x30): Unable to read reg(0x19).
<8> Feb 12 15:14:42 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1793 %% CPLD(0x30): Unable to read reg(0x1a).
<8> Feb 12 15:14:42 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1796 %% CPLD(0x30): Unable to read reg(0x02).
<8> Feb 12 15:14:42 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1321) 1797 %% CPLD(0x30): Unable to write data(0x00)@reg(0x02).
<8> Feb 12 15:14:44 192.168.0.239-1 BSP[boxs Req]: cpu_utils.c(1293) 1798 %% CPLD(0x30): Unable to read reg(0x50).
<8> Feb 12 15:14:46 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1800 %% CPLD(0x30): Unable to read reg(0x50).
<8> Feb 12 15:14:46 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1801 %% CPLD(0x30): Unable to read reg(0x02).
<8> Feb 12 15:14:46 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1321) 1802 %% CPLD(0x30): Unable to write data(0xa5)@reg(0x02).
<8> Feb 12 15:14:46 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1803 %% CPLD(0x30): Unable to read reg(0x10).
<8> Feb 12 15:14:46 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1804 %% CPLD(0x30): Unable to read reg(0x11).
<8> Feb 12 15:14:46 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1805 %% CPLD(0x30): Unable to read reg(0x19).
<8> Feb 12 15:14:46 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1806 %% CPLD(0x30): Unable to read reg(0x1a).
<8> Feb 12 15:14:46 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1809 %% CPLD(0x30): Unable to read reg(0x02).
<8> Feb 12 15:14:46 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1321) 1810 %% CPLD(0x30): Unable to write data(0x00)@reg(0x02).
<8> Feb 12 15:14:49 192.168.0.239-1 BSP[boxs Req]: cpu_utils.c(1293) 1813 %% CPLD(0x30): Unable to read reg(0x50).
<8> Feb 12 15:14:50 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1814 %% CPLD(0x30): Unable to read reg(0x50).
<8> Feb 12 15:14:50 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1815 %% CPLD(0x30): Unable to read reg(0x02).
<8> Feb 12 15:14:50 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1321) 1816 %% CPLD(0x30): Unable to write data(0xa5)@reg(0x02).
<8> Feb 12 15:14:50 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1817 %% CPLD(0x30): Unable to read reg(0x10).
<8> Feb 12 15:14:50 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1818 %% CPLD(0x30): Unable to read reg(0x11).
<8> Feb 12 15:14:50 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1819 %% CPLD(0x30): Unable to read reg(0x19).
<8> Feb 12 15:14:50 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1820 %% CPLD(0x30): Unable to read reg(0x1a).
<8> Feb 12 15:14:50 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1823 %% CPLD(0x30): Unable to read reg(0x02).
<8> Feb 12 15:14:50 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1321) 1824 %% CPLD(0x30): Unable to write data(0x00)@reg(0x02).
<8> Feb 12 15:14:52 192.168.0.239-1 BSP[boxs Req]: cpu_utils.c(1293) 1825 %% CPLD(0x30): Unable to read reg(0x50).
<8> Feb 12 15:14:54 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1826 %% CPLD(0x30): Unable to read reg(0x50).
<8> Feb 12 15:14:54 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1827 %% CPLD(0x30): Unable to read reg(0x02).
<8> Feb 12 15:14:54 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1321) 1828 %% CPLD(0x30): Unable to write data(0xa5)@reg(0x02).
<8> Feb 12 15:14:54 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1829 %% CPLD(0x30): Unable to read reg(0x10).
<8> Feb 12 15:14:54 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1830 %% CPLD(0x30): Unable to read reg(0x11).
<8> Feb 12 15:14:54 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1831 %% CPLD(0x30): Unable to read reg(0x19).
<8> Feb 12 15:14:55 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1832 %% CPLD(0x30): Unable to read reg(0x1a).
<8> Feb 12 15:14:55 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1835 %% CPLD(0x30): Unable to read reg(0x02).
<8> Feb 12 15:14:55 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1321) 1836 %% CPLD(0x30): Unable to write data(0x00)@reg(0x02).
<8> Feb 12 15:14:55 192.168.0.239-1 BSP[boxs Req]: cpu_utils.c(1293) 1837 %% CPLD(0x30): Unable to read reg(0x50).
<8> Feb 12 15:14:58 192.168.0.239-1 BSP[boxs Req]: cpu_utils.c(1293) 1838 %% CPLD(0x30): Unable to read reg(0x50).
<8> Feb 12 15:14:59 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1839 %% CPLD(0x30): Unable to read reg(0x50).
<8> Feb 12 15:14:59 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1840 %% CPLD(0x30): Unable to read reg(0x02).
<8> Feb 12 15:14:59 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1321) 1841 %% CPLD(0x30): Unable to write data(0xa5)@reg(0x02).
<8> Feb 12 15:14:59 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1842 %% CPLD(0x30): Unable to read reg(0x10).
<8> Feb 12 15:14:59 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1843 %% CPLD(0x30): Unable to read reg(0x11).
<8> Feb 12 15:14:59 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1844 %% CPLD(0x30): Unable to read reg(0x19).
<8> Feb 12 15:14:59 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1845 %% CPLD(0x30): Unable to read reg(0x1a).
<8> Feb 12 15:14:59 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1848 %% CPLD(0x30): Unable to read reg(0x02).
<8> Feb 12 15:14:59 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1321) 1849 %% CPLD(0x30): Unable to write data(0x00)@reg(0x02).
<8> Feb 12 15:15:02 192.168.0.239-1 BSP[boxs Req]: cpu_utils.c(1293) 1850 %% CPLD(0x30): Unable to read reg(0x50).
<8> Feb 12 15:15:03 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1851 %% CPLD(0x30): Unable to read reg(0x50).
<8> Feb 12 15:15:03 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1852 %% CPLD(0x30): Unable to read reg(0x02).
<8> Feb 12 15:15:03 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1321) 1853 %% CPLD(0x30): Unable to write data(0xa5)@reg(0x02).
<8> Feb 12 15:15:03 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1854 %% CPLD(0x30): Unable to read reg(0x10).
<8> Feb 12 15:15:03 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1855 %% CPLD(0x30): Unable to read reg(0x11).
<8> Feb 12 15:15:03 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1856 %% CPLD(0x30): Unable to read reg(0x19).
<8> Feb 12 15:15:03 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1857 %% CPLD(0x30): Unable to read reg(0x1a).
<8> Feb 12 15:15:03 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1860 %% CPLD(0x30): Unable to read reg(0x02).
<8> Feb 12 15:15:03 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1321) 1861 %% CPLD(0x30): Unable to write data(0x00)@reg(0x02).
<8> Feb 12 15:15:05 192.168.0.239-1 BSP[boxs Req]: cpu_utils.c(1293) 1862 %% CPLD(0x30): Unable to read reg(0x50).
<11> Feb 12 15:15:05 192.168.0.239-1 DRIVER[sfpDiagCacheMon]: hpcsfp.c(489) 1863 %% s/p(0/8): Task: sfpDiagCacheMonTask, plugged in Transceiver is not accessible. Please re-insert or chec.
<11> Feb 12 15:15:05 192.168.0.239-1 DRIVER[sfpDiagCacheMon]: hpcsfp.c(489) 1865 %% s/p(0/8): Task: sfpDiagCacheMonTask, plugged in Transceiver is not accessible. Please re-insert or chec.
<8> Feb 12 15:15:07 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1868 %% CPLD(0x30): Unable to read reg(0x50).
<8> Feb 12 15:15:07 192.168.0.239-1 BSP[hwMonTask]: cpu_utils.c(1293) 1869 %% CPLD(0x30): Unable to read reg(0x02).
