gregarican
Nov 02, 2021Aspirant
M4300-16X Port Mirroring
So I have a single M4300-16X that I'm trying to configure for traffic analysis. Looking at the CLI documentation, it appears straightforward enough. The current config is nothing special. Default VLA...
gregarican
And here is the current config up until the point I attempted the port mirroring.
!Current Configuration: ! !System Description "M4300-16X ProSAFE 16-port 10GBASE-T with PoE/PoE+ support, 12.0.9.3, B1.0.0.15" !System Software Version "12.0.9.3" !System Up Time "0 days 20 hrs 9 mins 37 secs" !Additional Packages QOS,Multicast,IPv6,IPv6 Management,Stacking,Routing !Current SNTP Synchronized Time: Mar 19 13:14:23 2021 UTC ! vlan database vlan routing 1 1 exit configure stack member 1 11 exit username "admin" password xxxxxxxxxxx level 15 encrypted username snmpv3 authentication "admin" md5 line console serial timeout 30 exit line telnet exit line ssh exit snmp-server sysname "XXXXXXX" snmp-server location "XXXXXXX" snmp-server contact "XXXXXXX" ! interface vlan 1 routing ip address dhcp exit router rip exit router ospf exit ipv6 router ospf exit exit
gregarican
Nov 03, 2021Aspirant
...anyone???
The one caveat I think _could_ be affecting things is that the switch has been up for almost 8 months now. And has run into a known bug where the web GUI, SSH access, etc. has been knocked off. The only apparent solution to that bug is rebooting the switch itself. Although a core production switch makes that workaround pretty clumsy at best. I hope to do that this Sunday and will see if I then can add this mirrored port after the reboot.
