kriters
May 14, 2023Follower
M4300-24X - multiple sudden restarts
Hi, Has anyone got confirmation that heat is the cause of restarting the switch ? Did replacing a factory installed PSU help ? I`m having restarts quite often - twice a day or one restart in 2-3 d...
LaurentMa
Oct 18, 2024NETGEAR Expert
Sorry for this issue, I believe we have addressed it fully in previous firmware versions. Please plan for a maintenance window and upgrade to the latest M4300 firmware version, 12.0.19.4
I trust this will fix this issue.
https://www.netgear.com/support/product/m4300/#download
maindriver
Oct 19, 2024Apprentice
Hi Laurent,
This is already on the latest firmware
- LaurentMaOct 21, 2024NETGEAR Expert
Hi maindriver
Sorry to hear, it means that they are other possible issues - we need to open a case at our Technical Support in this is an IT installation, or at [email protected] if this is an AV installation.
Please start with an email at [email protected] with a link to this thread, and with the Tech Support file out of this switch or stack (AVUI Diagnostics/Support Diagnostics; or IT GUI Maintenance/Export/HTTP File Export/tech-support in the drop down list).
In the tech-support file, we will be able to understand better what is happening here!
