Carva's avatar
Carva
M4300-24X Routing guide
Hi Sir,
I would like to deploy OSPF & RIP protocol using M4300-24X.
May I know if do you have an example scenario of document to refer to?
Thanks.
C.
  • Retired_Member's avatar
    Retired_Member
    Hi Carva,
    Welcome to the community!
    For dynamic routing protocol(RIP&OSPF) admin guide, please refer to M4300 Software Administratrion Manual. Click the Link and go to Chapter 6(RIP) and Chapter 7(OSPF) for typical scenario configuration.
    Hope it helps!
    EricZ
    NETGEAR employee
      Retired_Member
      Hi Carva,
      I just want to follow-up on this. Does this suggestion resolve your problem?
      With regard to resolve your problem, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
      • Carva's avatar
        Carva
        Hi Eric,
        Thanks for the quick response and support.
        May I know if do you have some example scenario that I could refer to?
        The guide that you provide is good, but I still don't know how to implement it in a real network environment.
        Thanks.
        C.
ProSupport for Business
