Norbert_T
Mar 06, 2018Aspirant
M4300 24X24F Stack Bandwidth
Hi,
we are trying to build a core setup with 4x M4300 24x24 switches.
We want to split the core into 2 switches per fire zone, but keep them working as one logical unit by using stacking in ring topology. As far as we understand, we can increase the stacking bandwidth by using more then one stacking connection per switch, so we decided to use 3x 10Gbit copper cables to connect to direct neighbor and 3x 10 Gbit SFP+ for connecting to room neighbor. When viewing stack diagnostics, web interface show only one path nstead of 3 paths. How can we ensure that all stack connections are used for highest bandwith or does using multiple connections only provides redundancy in case one link is down?
Thanks for your help,
Norbert
Our Setup looks like this:
CORE
Room1 Room2
SW1 ----- SW3
SW2 ----- SW4
- LaurentMaNETGEAR Expert
Hi Norbert_T
Thank you for your message and congratulations, NETGEAR M4300 series is world-class for high performance and nonstop forwarding (NSF) stacking topologies.
If System \ Stacking \ Advanced \ Stack-port Diagnostics show 1 path, it might indicate other "stack ports" are not working. Are we sure System \ Stacking \ Advanced \ Stack-port Configuration shows all your Stack Ports with "stack" in both Configured Stack Mode and Running Stack Mode for ALL units?
If not, the stack should be initialized again, one switch after the other?
Please let the Community know.
- Norbert_TAspirant
Hi LaurentMa,
thanks for your fast response. Reint of stack did not help, current firmware is 12.0.2.6, Please see my configured Stack-Ports
Thanks, Norbert
SW1
1 0/19 SFP+ AXM761 Stack Stack Link Up 10
1 0/21 SFP+ AXM761 Stack Stack Link Up 10
1 0/23 SFP+ AXM761 Stack Stack Link Up 101 0/43 Stack Stack Link Up 10
1 0/45 Stack Stack Link Up 10
1 0/47 Stack Stack Link Up 10SW2
2 0/19 SFP+ AXM761 Stack Stack Link Up 10
2 0/21 SFP+ AXM761 Stack Stack Link Up 10
2 0/23 SFP+ AXM761 Stack Stack Link Up 102 0/43 Stack Stack Link Up 10
2 0/45 Stack Stack Link Up 10
2 0/47 Stack Stack Link Up 10SW3
3 0/19 SFP+ AXM761 Stack Stack Link Up 10
3 0/21 SFP+ AXM761 Stack Stack Link Up 10
3 0/23 SFP+ AXM761 Stack Stack Link Up 103 0/43 Stack Stack Link Up 10
3 0/45 Stack Stack Link Up 10
3 0/47 Stack Stack Link Up 10SW4
4 0/19 SFP+ AXM761 Stack Stack Link Up 10
4 0/21 SFP+ AXM761 Stack Stack Link Up 10
4 0/23 SFP+ AXM761 Stack Stack Link Up 104 0/43 Stack Stack Link Up 10
4 0/45 Stack Stack Link Up 10
4 0/47 Stack Stack Link Up 10In System --> Stacking --> Stack-port Diagnostics ---> ALL, I can see the following Stack-Port packet path:
Direction Packet-path from unit2 to unit1 unit-2 port 2/0/43 to unit-1
Total hop count: 1from unit3 to unit1 unit-3 port 3/0/19 to unit-1
Total hop count: 1from unit4 to unit1 unit-4 port 4/0/21 to unit-1
Total hop count: 1- Norbert_TAspirant
Hi LaurentMan,
I upgraded to firmware 12.0.2.20 and did a complete factory reset. After that I tried to build a stack between SW1 and SW2 by using 3x 10G copper connections. The packet-path summary shows, that only one stack connection is used.
For me this means that only 1x 10G port is in use, while port 2/0/45 + 2/0/47 are not.
Thanks, Norbert
Total hop count: 1
