goomisch
Jul 26, 2024Initiate
M4300-24X24F UI problem
Hello Everyone,
I have a problem with UI on the switch. AVUI is working but if I try to switch to MainUI - it not works.
Switch configuration
(WABAGSWDC001) #show ip http
HTTP Mode (Unsecure)........................... Disabled
HTTP Port...................................... 80
Maximum Allowable HTTP Sessions................ 16
HTTP Session Hard Timeout...................... 24 hours
HTTP Session Soft Timeout...................... 15 minutes
HTTP Mode (Secure)............................. Enabled
Secure Port.................................... 49152
Secure Protocol Level(s)....................... TLS1.2
Maximum Allowable HTTPS Sessions............... 16
HTTPS session hard timeout..................... 24 hours
HTTPS session soft timeout..................... 15 minutes
Certificate Present............................ True
Certificate Generation In Progress............. False
I'm rediredtied to https://10.10.0.30:49152/v1/base/cheetah_login.html
I don't have any ideas except factory default 😞
Mayby important information - it's a stack of 2 identical switches. Software 12.0.17.19, I tried downgrade to 12.0.17.16 and .10 - there was even worse because AVUI not worked at .10
- RennaDNETGEAR Moderator
Hi goomisch,
Welcome to the NETGEAR Community! 🙂
The Main UI is not accessible because the HTTP is disabled and HTTPS is probably not configured properly. To re-enable HTTP type the command "ip http server" on the CLI Privileged EXEC mode.example:
(WABAGSWDC001)# ip http server
Have a lovely day,
RennaD
Netgear Team
- goomischInitiate
Problem solved. It was a firewall issue, after policy update everything work correct. Not allowed port 49151-49152 from vpn to subnet.
