TechAtAnimal
Jun 27, 2017Aspirant
M4300 24x24f unresponsive- amber power light
Hi! We have an m4300x24f managed switch. It is an RMA replacement so was hooked in three weeks ago. When we plugged it into the power it worked great three weeks ago, was able to log in just to make ...
TechAtAnimal
Jun 28, 2017Aspirant
The Power 1 light is solid amber and we only have the one PSU however, it does the same thing if we switch the PSU to slot number 2 just with the Power 2 light. None of the ports are responding, they don't give any indicator lights to show that they are plugged into the computer with the computer not acknowledging that anything is plugged in and we can't pull up any info from the switch.
Thank you for responding
TCan
Have you plugged in a console cable so you can follow the whole boot process and see if any error message is displayed?
