maindriver's avatar
maindriver
Apprentice
Oct 11, 2019
M4300-48X - Where are BOOTP relay settings?
We're replacing an old Allied Telesis core switch with a M4300-48X, this will be our primary core switch in the business.  I'm struggling to find the BOOTP relay settings.
From my understanding, this is in place to tell the devices on a specific VLAN which IP to use for their BOOTP/DHCP server.  On this current switch, we have some IPTV gateways and IPTV set top boxes that are defined in this section of the switch.
IE, anything on VLAN50 (IPTV) for example, BOOTP RELAY is set as 192.168.1.40 (the media esrver)
So I have a list of VLANs and their specific BOOTP RELAY
bootp relay=192.168.1.1 int=vlan3
bootp relay=192.168.1.1 int=vlan4
bootp relay=192.168.1.1 int=vlan5
bootp relay=192.168.1.1 int=vlan6
bootp relay=192.168.1.40 int=vlan50
bootp relay=192.168.1.1 int=vlan60
Currently looking through the GUI of the Netgear switch.
1 Reply
  • Hi
    I primarily use our M4300's in CLI mode so I can't even tell you much about the GUI side ;)
    Anyhow, have a look at the CLI reference guide. For 'ip helper enable' there is a note about bootp:
    Use this command to enable relay of UDP packets. [...] This command replaces the bootpdhcprelay enable
    command, but affects not only relay of DHCP packets, but also relay of any other protocols for which
    an IP helper address has been configured.
    Since bootp and DHCP use the same ports, defining a DHCP helper should work? I haven't done ip helpers on the M4300 yet, but I guess that defining a ip helper address not on the physical port but on the VLAN interface could do the trick. (At least that's what I've done with other vendors)
    Would be interesting to hear back from you if I was entirely wrong or at least pointing into the right direction.
ProSupport for Business
