TurskRO's avatar
TurskRO
M4300-52-PoE+ and NMS300
I have a stack of M4300-52-PoE+ switches that I'm trying to add to NMS300 software. When I do a discovery it says credential failure. I'm running NMS300 version 1.7.0.12 and switch firmware 12.0.17.7.
I know I'm using the correct credentials so I don't know what is going on. My S3300's discover no problem.
Help!
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    TurskRO,
    There is no M4300-52-PoE+ switch model.  I believe you are referring to the M4300-52G-PoE+ switch model.
    As indicated in the NMS300 user manual, "If a credential failure occurs, a common reason is that the device login information changed from its default. When a credential failure occurs, add or modify the credential and run the discovery job again."  Kindly read pages 38-42 of the NMS user manual here on how to add or modify a device credential.
    Also, try to connect the PC/laptop directly hardwired to the M4300-52G-PoE+ switch then check again if it will be discovered by the NMS300.
    DaneA
    NETGEAR Community Team
    • TurskRO's avatar
      TurskRO
      Yes, I have done exactly this. I have also change the credentials back to default and tried to use the default http credentials to discover it. None of this works.
      • DaneA's avatar
        DaneA
        TurskRO,
        I found this old community thread here.  Kindly read it and see if it helps.
        DaneA
ProSupport for Business
