scolson's avatar
scolson
Follower
Jun 28, 2017
M4300-52G ProSAFE 4G24725T000C6 force speed 1G
Hi,
I have a stack of 6 M4300-52G
I try to force a port 1G in a 1G speed
when I try in cli I have the choise of 10mb 100mb and 10G
it's not a 10G port
you can see a print screen of the cli http://imgur.com/a/O0eKT
best regards,
  • My guess would be that you don't have that as a choice as it is the default speed.
    If you have a piece of equipment that you believe is 1Gb but connecting at a lower speed then I would try another cable as a faulty cable will cause this issue (assuming you have checked the settings on the other equipment and it isn't faulty). Also check there is no damage to the ethernet ports.
  • ElaineP's avatar
    ElaineP
    NETGEAR Expert
    Hi  scolson,
    Under one interface, you can configure ‘speed auto 1000’ to force 1G speed. Due to M4300-52G still support 10G speed for other ports(port49,50,51,52), so under any interface, 10G speed can be seen. The switch displays all speeds for every interface.
    NETGEAR Employee
ProSupport for Business
