cvelarde
Feb 20, 2018Follower
M4300-52G VLAN can not be seen between them
Hello, I need to configure one vlan per port of my switch, and route all by one direction. What I need is that they can not be seen between them. If they have any guide or how it is done, I will be...
JohnC_V
Feb 21, 2018NETGEAR Employee Retired
Hi cvelarde,
Welcome to our community!
We can do that by creating asymmetric VLAN. Please follow the steps below:
- Connect your PC to port 1 of the switch and login to its admin interface. How do I access the admin page of my ProSAFE Fully Managed Switch?
- Create VLAN for uplink and for each port. Leave the port 1 as your management port and remain in VLAN 1 as we are going to separate the uplink port to your router. How to configure a VLAN on a NETGEAR managed switch?
VLAN 99 - UPLINK - Port 48 - Switch to Router
VLAN 12 - PORT2 (Port number as VLAN name)
VLAN 13 - PORT3
etc.
Add ports to the VLAN:
- Go to Switching - VLAN - Advanced - VLAN Membership.
- In the VLAN ID drop down menu, select the VLAN ID you want to edit.
- Select the ports to add to the VLAN. You need to mark a port as untagged.
- Go to Switching - VLAN - Advanced - Port PVID Configuration.
- For each port marked as untagged above, set the PVID of that port to the VLAN ID of the VLAN it was assigned to.
e.g.
VLAN 99 - All ports - U - Assign Port 48 as Uplink, so port 48 - PVID 99
VLAN 12 - Port 2 - U - PVID 12
VLAN 13 - Port 3 - U - PVID 13
VLAN 14 - Port 4 - U - PVID 14
etc.
Try to connect another PC to port 2 and 3, then test if it will be receiving an IP from your designated DHCP server and check if it will communicate to each other.
