cvelarde
Feb 20, 2018Follower
M4300-52G VLAN can not be seen between them
Hello, I need to configure one vlan per port of my switch, and route all by one direction. What I need is that they can not be seen between them. If they have any guide or how it is done, I will be...
JohnC_V
Feb 26, 2018NETGEAR Employee Retired
I would like to have a follow up on this thread. Please let us know if everything is ok now or you still need further assistance.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
