igor_goienetxea
May 16, 2019Aspirant
M4300 gratuitous arp
Hi,
I have a question about gratuitous arp,
We have a network of Netgear M4300 switches with:
- M4300-28G switches - Access (Version 12.7.10)
- M4300-96X - Core (Version 12.7.10)
Th...
igor_goienetxea
May 17, 2019Aspirant
Thank you very much for your answer LaurentMa!!!
I´ve some doubt about it:
- I´ve seen in this command in the documentation: ip unnumbered gratuitous-arp accept ¿Is it only for L3?
- what is it for? An example of implementation?
Regards
LaurentMa
May 17, 2019NETGEAR Expert
Hi,
Please consult the CLI admin guide from https://www.netgear.com/support/product/m4300.aspx#docs
Direct link to the guide: http://www.downloads.netgear.com/files/GDC/M4300/M4300-M4300-96X_CLI_EN.pdf
The M4300 have minimum commands for querying IP address conflicts, and for handling incoming Gratuitous ARP messages this way:
Page 276:
ip address-conflict-detect run
This command triggers the switch to run active address conflict detection by sending gratuitous ARP packets for IPv4 addresses on the switch.
show ip address-conflict
This command displays the status information corresponding to the last detected address conflict.
clear ip address-conflict-detect
This command clears the detected address conflict status information.
Page 641:
This command enables the switch to automatically configure static interface routes to an unnumbered peer when the switch dynamically receives gratuitous ARP messages. The switch uses the IP address of the loopback interface (see the ip unnumbered loopback command) as the IP address for the unnumbered peer. This behavior is enabled by default.
no ip unnumbered gratuitous-arp accept
This command prevents the switch from automatically configuring static interface routes to an unnumbered peer when the switch dynamically receives gratuitous ARP messages.
Hope this helps,
