PawelKopec
Jan 30, 2018Initiate
M4300 (GSM4352PS V1) : can't get kernel image
Hi Netgear Users and Administrators,
I have a little problem with my M4300 GSM4352PS V1. There's possibility that image2 is broken. Device is actually booting from image2. On the console I see that can't boot from image and i see "ERROR: can't get kernel image". I supose that the image1 is a good conditional.
Best Redgards
Pawel
- PawelKopecInitiate
On the console a get this info
m4300r2> reset
resetting M4352PS board...
U-Boot 2012.10-00216-g55eda36 (May 25 2016 - 15:31:45)VerNo=1.0.0.8
/image2 not found!
ubifsload - load file from an UBIFS filesystem
Usage:
ubifsload <addr> <filename> [bytes]
- load file 'filename' to address 'addr'
Wrong Image Format for bootm command
ERROR: can't get kernel image!
Saving Environment to SPI Flash...
/image1 not found!
Usage:
/image2 not found!
- boeLuminary
I'm having a similar issue.
Usage:
ETH LINK UP: 1000FD
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5Retry count exceeded; starting again
Abort
m4300r2> setenv bootfile = image2
m4300r2> reset
U-Boot 2012.10-00245-g79946b8c89 (Feb 21 2018 - 17:08:40)VerNo=1.0.0.11/image2 not found!
ubifsload - load file from an UBIFS filesystemUsage:
/image1 not found!
/image2 not found!
ETH LINK UP: 1000FD
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4Abort
- boeLuminary
